1996 Chevy Tahoe Fan not working, then working
254,000 MILES • V8 • 4WD • AUTOMATIC
HOWDOO88
Twice now when I have turned on the heat the fan does not work for most of the morning then after awhile it kicked in and started working. What do I need to do to fix this?
Thanks
Dec 20, 2009 at 5:07 AM
JDL
  • 16,098 POSTS
Welcome, I'd check voltage and ground at the blower motor connector, when the problem occurs. If voltage and ground are good, I suspect the blower motor. Whether a problem with wiring circuit or blower motor, if you hit a bump, it may start working?
Dec 20, 2009 at 5:22 AM
