my Tahoe has started running rough. when code is read it says misfire on #2 cyl. the thing is, when its cold its ok but right at 180 deg it sets the engine light on
. Ive changed plugs & wires but its still on #2. mechanic says its probably injectors, so I ran cleaner but no help.
Any suggestions from somebody that has had similar problems. I also changed cap & rotor. No change.
Dec 7, 2009 at 12:06 PM
