1996 Chevy Tahoe 96 tahoe hard start when hot
TRAVCMBS
Engine Mechanical problem
1996 Chevy Tahoe V8 Four Wheel Drive Automatic
96 Tahoe stars runs fine when cold when its warm won't start without holding fuel pedal down cranks a while starts its flooded runs at 2k for 15 20 sec, after it settles down it runs fine. New cap rotor wires plugs fuel and air filter fuel pressure 55# 180000 miles. Thanks Travis
Nov 14, 2009 at 10:16 AM
  • 110,248 POSTS
Travis:
I would start by having the ambient temp sensor tested. IT may be telling the computer it is very cold out which will cause the computer to run a very rich mixture to the engine for a cold start.
Check that and let me know what you find.
Nov 29, 2009 at 10:57 AM
TRAVCMBS
I'M LEANING THAT WAY i PUT IN A SUPPOSEDLY GOOD SPIDER STILL THE SAME MAYBE NOT AS BAD . DO YOU THINK AIR TEMP OR MAY BE WATER TEMP? THANKS TRAV
Nov 30, 2009 at 12:46 PM
