1996 Chevy Tahoe ?
BUBSTER1218
Transmission problem
1996 Chevy Tahoe 6 cyl Four Wheel Drive Automatic
All of a sudden, It acted like it wanted to die, speedo went nuts, then stopped working. It wont shift out of 1st gear even with the shifter, when it does shift, it is at a high rpm then it shifts very hard. checked all the fuses i could find, i.e. under the hood, in the dash. have never had any problems like this before. Please help.
Aug 2, 2009 at 6:36 AM
  • 110,248 POSTS
It sounds like either a shift solenoid or vehicle speed sensor problem. Has the check engine light come on? I am assuming the ATF is full.
Aug 10, 2009 at 1:17 PM
