1996 Chevy Tahoe
RODNEYT
Electrical problem
1996 Chevy Tahoe V8 Four Wheel Drive 15000 miles
i have a 1996 tahoo 4X4 i got no spark.tride every thange
Apr 5, 2009 at 8:58 AM
DOCFIXIT
  • 18,828 POSTS
tell what has been done?
Apr 5, 2009 at 9:04 AM
RODNEYT
wow that was fast.i changed the coil and the moduler and fule pump and crank shaft sensor .next thang is the pcm.i got no power gowing to the coil and moduler.i thank i got a shorte some wear.it was fine then last weak i was gowing to work and it didnt want to start.i finley got it to start and got a few blocks and it dyed on me.took a few minuites and got it started agen and went home now it is dead.i thought it was the fule pump.becous a few days befor i ran it out of gas.so i changed that .went to start and have no spark tested almost every thang not sure to shoot it or what.
Apr 5, 2009 at 9:45 AM
DOCFIXIT
  • 18,828 POSTS
Got a couple of things first Cam shaft sensor in Distributor and Coil Driver located right rear side of engine. Fault in either one will cause coil not to fire
Apr 8, 2009 at 7:12 AM
