1995 Chevy Tahoe Wont start
SCCERPLAYER19
Engine Performance problem
1995 Chevy Tahoe V8 Four Wheel Drive Automatic
I have a new fuel pump, fuel filter, tune up, but my truck will not start. i have pressure to the fuel injectors. when i prime the truck it will start fine, but will die right after it runs out.
Apr 6, 2008 at 10:31 AM
JDL
  • 16,098 POSTS
My info shows you have a TBI fuel system. With the engine cranking, you should be able to see an injector spray pattern, do the injectors spray. Even if there is a spray pattern, that doesn't mean the pressure is ok. It does mean the computer is pulsing the injectors.
If there is no injector pulse, the first thing I look for, is an rpm signal. Without that signal, the injectors won't pulse. Are there any troublecodes?
Apr 7, 2008 at 6:18 AM
