1995 Chevy Tahoe Part name
162,000 MILES • V8 • 4WD • AUTOMATIC
PETEREY2
I am trying to diagnose why i have no heat. I found that the heater control valve that lets coolant go to and thru the heater core is not opening. I need to know what the part is that sends vacuum to the valve. This part is located on the accumulator. it has a 2 wire connector going to it and one vacuum line coming out of it that goes to the heater control valve. Thanks in advance.
Jan 27, 2010 at 12:22 PM
OBXAUTOMEDIC
  • 3,711 POSTS
I believe it is either a Vacuum Selenoid, Vacuum Pump or a Vacuum Switch.
Have you tested for power to the part in question.
Jan 27, 2010 at 1:09 PM
