1995 Chevy Tahoe not cooling
BAMAGIRL86
  • 1995 CHEVROLET TAHOE
Air Conditioning problem
1995 Chevy Tahoe 6 cyl Automatic 200000 miles
My air connditioner is not cooling. It blows out warm air. Do you think it needs freon(may be spelled wrong) or could it be something more. It has coolant.
Tuesday, June 8th, 2010 AT 5:09 PM
You need to check the high and low pressure to determine if it needs freon this is your starting point
Wednesday, June 9th, 2010 AT 5:09 AM
JAMIESBAKER21
  • 6 POSTS
Go to the auto parts store and buy you a cheap A/c gage and about 3 cans of freon. Make sure you place the cans of freon in hot water when injecting into the vechicle. Thsi will cause the gas to leave the can faster and do not turn the can upside down. If the A/c beging to cool it has a leak somewhere. If it doesn't cool the compressor may be bad. Look and see if the compressor is cycling on a off. If not then try the freon and it should begin to cycle.
Sunday, June 13th, 2010 AT 3:50 PM
