1995 Chevy Tahoe No oil pressure indicated
220,000 MILES • V8 • 2WD • AUTOMATIC
JIMMCCAIN
I recently changed the automatic transmission, and have not had oil pressure indicated since, although the engine runs fine and obviously actually DOES really have oil pressure.
Where is the oil pressure sensor located physically on this pre-vortec 5.7 V8 engine? I feel that it's only a wire disconnected, but so far I've not found the sending sensor. Of course, if the sensor has just coincidentally failed (unlikely) I'll still need to know where it is to replace it.
Regards,
Jim
Aug 13, 2008 at 2:12 PM
JIMMCCAIN
The sensor is not located near the filter, although there are several capped off connections nearby. This vehicle is fitted with what appears to be an oil cooling system going to the radiator and back, possibly part of a towing package. Are there any ports on the backside of the engine for oil pressure sensor? Remember that this problem started when the transmission was replaced.
Regards,
Jim
[quote:d02e3df908="legitimate007"]it should be right next to the oil filter, the wire could just be loose[/quote:d02e3df908]
Aug 14, 2008 at 10:37 AM
JIMMCCAIN
[quote:10996bdc0b="jimmccain"]The sensor is, in fact, slightly to the rear drivers side of the distributor, where it has apparently resided for a very long time, dating back into the days when it was still called a 350 and on at least into the early days of the Vortec as well. Thanks for trying.
[quote:10996bdc0b="legitimate007"]it should be right next to the oil filter, the wire could just be loose[/quote:10996bdc0b][/quote:10996bdc0b]
Aug 14, 2008 at 4:47 PM
MERLIN2021
  • 17,250 POSTS
https://images.2carpros.com/forum/automotive_pictures/62217_ops_1.jpg
It's next to the distributor, location #8
Aug 15, 2008 at 4:12 AM
LEGITIMATE007
  • 5,121 POSTS
your welcome
Aug 15, 2008 at 6:32 AM
