Engine Performance problem
1995 Chevy Tahoe V8 Four Wheel Drive Automatic 175K miles
when i go to turn on the tahoe in hot weather the orange light under the P does not show up and when i apply the brake and switch it to reverse and so forth the light still does not come on, all of the gauges work except for the MPH and the RPM, and when I put it into drive the truck starts in 2nd gear and wont go down into first and it doesnt go into 4th so when im on the freeway im at about 2500 rpm goin 60, this problem only occurs when it is hot because at night time the truck runs fine and in the early hours of the morning the truck works fine, any suggestions? thanks.
Aug 28, 2009 at 3:22 PM
