1995 Chevy Tahoe Coolant leaking
137,000 MILES • V8 • 4WD • AUTOMATIC
STEWBOMB7
I just recently notice something was leaking, when you first start up the car you can see it leaking and it in a spray patern on the ground like its shooting of the belts, i looked under the hood and the belts are wet with coolant/antifreeze seems to be leaking from the water pump im guessing. When you turn vehicle off a steady short stream runs out the bottom then stops.
Mar 5, 2008 at 8:42 AM
M8TRIX01
  • 36 POSTS
Yes it is probably comming from the water pump weep hole. Which means a new water pump.
Mar 5, 2008 at 8:44 AM
