1995 Chevy Tahoe controls
180,000 MILES • V8 • 4WD • AUTOMATIC
JUGGALETTE332006
The heat in the tahoe works fine, blows hot except it ONLY blows out of the floor. No matter what you put the control on it blows from the floor and no where else.
Dec 6, 2008 at 11:10 PM
  • 110,246 POSTS
Hi:
There are vent doors in the HVAC duct work that direct the air. Either you have a vacuum leak between the engine, switch, and vent doors, or the doors are damaged or stuck. Check for vacuum leaks first. That is the most common problem.
Dec 16, 2008 at 12:27 PM
