1995 Chevy Tahoe brake light switch
WENDY72
Brakes problem
1995 Chevy Tahoe Automatic
the brake lights won't work on my truck. we replaced the brake light switch, but the piece will not stay in place on the small rod that it slides on to. do you what could fix this.
Sep 12, 2010 at 6:56 AM
TAHOE1996
[quote:e7287c71ec="wendy72"]Brakes problem
the brake lights won't work on my truck. we replaced the brake light switch, but the piece will not stay in place on the small rod that it slides on to. do you what could fix this.[/quote:e7287c71ec]
I am also having a problem with my Chevy Tahoe's brake light switch. Originally, I was pulled over by the police and told my brake lights were out. I troubleshot it to the brake light switch. I replaced the switch and everything worked for a while. Eventually, it happened again...and again...and again. I keep having to slide the switch back into place because it gets very loose. I recently purchased this 1996 Tahoe from someone off Craigslist. He told me he had "just replaced the brake booster". So I know they were messing with the brakes. All that is securing the brake light switch in place is an "E" Clip of some type. As I research this more and more, I realize that this "E" Clip is not original to the truck and this guy shoved it in there as a quick fix. Bottom line, does anyone have a diagram or part number for this brake light switch retaining clip or a parts breakdown? Where can I order this too. Thank You.
Sep 26, 2010 at 4:46 PM
