DO THE ROTORS JUST SLIP OFF OR DO I UNSCREW THE SPINDAL WHERE THE BEARINGS ARE OR WHAT?
Apr 26, 2009 at 4:43 AM
PEAR69
✓Experienced Mechanic
Remove the hub nut and the rotor will come off. Be sure to inspect the hub bearings and repack them properly. You should REPLACE the hub nut with a new one.
