Transmission or rear end problem
NRMEDIC
I have a 1999 Suburban with a 5.7. When stopped at a light, especially on a down-hill, when you take your foot off the brake to move to the accelerator there is a "clunk" sound. Can't tell if it's the transmission or coming from the rear end. Feels like a backlash from slack as you go from the stop to the forward motion. It doesn't do it all the time, only occasionally. The drive shaft is OK, the shocks are bolted tight. The transmission also seems to take a little more time when going from neutral or park to drive. It moves quickly from neutral or park to reverse, like it suppose to. Any advise?
Jun 8, 2007 at 4:07 AM
CHRIS_KOLAR
  • 10 POSTS
There is a special lube for the driveshaft slip yoke. You can get it from the dealer only. You only need about a 2 tablespoon's and may be able to get some from a tranny shop. Sometimes the slip shaft for the steering column can do this too. you would also feel that through the steering wheel. I hope these ideas help. chris
Aug 5, 2007 at 5:08 PM
