MEADENGR
I have a 1996 chev suburban, 5.7, 140,000 miles, front disc brakes.
My front driver side brake sticks and eventually heats up causing it to smoke. When brakes are applied the passenger side grabs and pulls vehicle to the right. Calipers have been replaced twice and brake system bled many times with same results.
Jun 15, 2007 at 12:46 PM
AACPLUS
  • 60 POSTS
Most likely the hose going to the caliper from the hard line is collapsed internally. To verify this, pull the tire and pump the brake pedal a few times, but do not keep pressure on the pedal after pumping it. Try to spin the hub by hand. if it is hard to turn or will not turn without aid of a tool, there is definitely a problem. Next, break loose the bleeder valve on the caliper. if the pressure is relieved and now spins easily, it is the brake hose. if it is still binding, it is the caliper.
Of course, it could also be due to the ABS or porportioning valve, or pads are incorrectly installed, if the caliper is still binding after performing the method above. but 99% of the time, it will be the hose or caliper.
Mar 15, 2021 at 4:37 AM
