2002 Chevrolet Suburban Door Locks on Bumps
MFLOOD
2002 chevy suburban 5.3L When I hit a bump driving down the road the power door locks engage and then disengage continually. I opened the fuse box and observed that when I hit the power locks the relay switch makes a loud clicking noise. Does this mean the switch is bad? If not any ideas on the problem. I read a post about modules in the door could that be the problem? Any guidance would be appreciated.
May 30, 2007 at 6:03 AM
2CARPRO JACK
  • 11,533 POSTS
Relays click when they are triggered, perfectly normal. Sounds like you might be onto something with the module, remove the door panel and see if you can simulate a bump and get it to malfunction
May 30, 2007 at 7:51 AM
Suggested Repair
Relay clicking when the locks are commanded is normal. Suspect a door lock module; remove the door panel and try to simulate a bump to reproduce the lock cycling.
Conversation Summary
A 2002 Chevrolet Suburban's power door locks engage and disengage repeatedly after hitting a bump. The owner noticed the lock relay clicking and asked whether the relay or a door module was bad. The expert said relay clicking when triggered is normal and recommended removing the door panel and simulating a bump to see if the module malfunctions.
