2002 chevy suburban 5.3L When I hit a bump driving down the road the power door locks engage and then disengage continually. I opened the fuse box and observed that when I hit the power locks the relay switch makes a loud clicking noise. Does this mean the switch is bad? If not any ideas on the problem. I read a post about modules in the door could that be the problem? Any guidance would be appreciated.
SPONSORED LINKS
Wednesday, May 30th, 2007 AT 1:03 PM
2CARPRO JACK
MECHANIC
Relays click when they are triggered, perfectly normal. Sounds like you might be onto something with the module, remove the door panel and see if you can simulate a bump and get it to malfunction
