Well, after pouring through many auto repair forums last night, I made a list of possible fixes. I then decided to approach my problem with the simplest repair attempt first. I removed the air intake housing, exposing the butterfly (throttle) valve. I held the flap open with one hand while I cleaned the inside with carb cleaner and a clean rag. I wiped everything I could get to. I started the Suburban and she idled as smooth as a baby's bottom. I guess it's idling around 600 or so RPM. The AC blows cold and the burb no longer lopes while idling. Amazingly simple and extremely inexpensive fix! If you are experiencing similar problems, I would urge you to try this first. :D
SPONSORED LINKS
Saturday, June 9th, 2007 AT 4:40 PM
