front end clanking while turning
GACOON
98 burb 4x4 5.7l 6inch pro comp lift 36inch BFG'S
history replaced ALL tie rod ends, both pitmans and aligned problem is when you turn the wheels while traveling makes a clunking noise and jumps a little. have noticed upper a arms hit shocks on both sides. do i need to replace bushings and bearings? little help would be great on this have owned many, but have never had this problem before.
Jun 17, 2007 at 8:08 AM
JKROBIN3
Did you ever find the cause of this ?
I have the same thing happening....except it seems to be coming from the left rear.
Sep 27, 2007 at 5:51 AM
LOWELL HUBBARD
I have a 2004 Chevolet 5.6 engine.Suburban with 66400 miles on it and I have in the last week notice a humming noise while driving it.I think it is a fan belt,but when I have the hood up i don't hear anything.
Help........Thanks .Lowell Hubbard
Wood2sides@yahoo,com
Nov 25, 2007 at 6:59 AM
DADDUBO
The noise could be the CV joint wearing, with it jacked up you are putting the CV joint at a higher angle the larger tires put more strain on it also. You say it is jerking that tell's me that it is in the drive line, also check and make sure that the 4 wheel drive has disengauged. Hope this helps
Nov 30, 2007 at 2:36 AM
