abs question
MINNESOTA10
I have a 2003 Suburban with 118,000 miles. Coming home from a trip yesterday the abs light went off in the truck, then went off. A little while later when braking, the pedal went further than normal and made a snapping noise, brakes still worked fine. The abs light stayed on for 150-160 miles, then went off. This morning did not come on, braked seem normal again
Sep 24, 2007 at 4:14 AM
MERLIN2021
  • 17,250 POSTS
The abs light can tell the dealer or shop that can read your abs codes what the problem is, if it self corrected, I would wait till it returns, the regular brakes will still funtion even if the abs is out, unless of coures you have a leak! But then Both lights would come on! In my experience when the light goes on and off a wheel sensor is either bad or loose...
Sep 24, 2007 at 7:32 AM
