1992 Chevrolet Suburban Rough After Plugs
KNARF
I CHANGED PLUGS AND CAP AND MY CAR RUNS LIKE ITS OUT OF TIME OR GAS AND I GOT GAS SO WHAT COULD MAKE THIS HAPPEN ????????????????ITS A 92 SUBURBAN WITH A V8 4X4
Jan 22, 2007 at 10:20 AM
BACKYARDMECHANIC
  • 337 POSTS
You could have one or two problems with the car. I'am assuming that the car ran ok before the tune up. First thing I can think of is you put the wires back on the wrong way and now the firing order is off. Also check that the wires are on tight and not grounding out. You can check this with the car running in the dark and look for electrical arcs. The other thing I can think of is the plugs were not gapped properly and need to be regapped.
Jan 22, 2007 at 10:35 AM
Suggested Repair
Confirm the engine ran normally before the tune-up. Recheck the spark-plug wire firing order, make sure each wire is seated tightly and not grounding, and inspect for arcing with the engine running in the dark. Also verify that the new plugs are gapped correctly and regap them if needed.
Conversation Summary
The owner of a 1992 Chevrolet Suburban V8 4x4 says it runs as if it is out of time or out of fuel after the spark plugs and distributor cap were replaced, despite having fuel. The expert assumes it ran properly before the tune-up and suggests incorrect plug-wire routing, loose or grounding wires, visible electrical arcing, or improperly gapped plugs.
