2008 Chevy Suburban tow package
2008 CHEVROLET SUBURBAN
3,000 MILES • V8 • 2WD • AUTOMATIC
PAMELA ANDERSON
where do I locate the electric brake hook-up for the controller.I was told it my be in the engine compartment,under the dash or in behind the glove box. please help!
Jan 22, 2008 at 7:11 PM
MASTERTECHTIM
  • 4,750 POSTS
its usually under the dash taped to a harness. once you connect it you have to go to the under hood fuse box and install a fuse for it, ther is no fuse from the factory, it will be labeled where to put the fuse. hope this helps
Jan 22, 2008 at 7:22 PM
