2007 Chevy Suburban service rear park assist message
45,000 MILES • V8 • 4WD • AUTOMATIC
FGDJR
Is there any way to test the rear park assist sensors? Maybe an ohm reading? There is 8 volts going to the sensors but the system won't operate. Just a red light at the back pillar. Any ides?
Feb 18, 2010 at 10:44 AM
BRIAN 1
  • 1,030 POSTS
have it scanned for dtc's,it too hard to diagnose without a code,on these A fault anywhere on the circuit or in any single sensor will affect all of the sensors.these sensors are wired in a series parallel.when testing it should have 8-9 volt reference.its easier to use a scan tool and switch sensors with different locations and see if the dtc sets on a different location,post back with the code.
Feb 18, 2010 at 12:20 PM
