I have replace plugs and wires ,even coil , clean out fuel system swap around injectors , on cylinder #7 and replace coil , still misfire . replace PCM and crank position sensor , had it flash at the dealer , still misfire check wires and ground to computer did a compression test ok, check for pulse at injectors ok ??? can any one help me ??
Nov 19, 2009 at 6:05 AM
