2006 Chevy Suburban Wireless Guage
CLEME1Q
Tires and Wheels problem
2006 Chevy Suburban
My Suburban has a wireless tire gauage system but when I got new tires the mechanic put the guages on the wrong tires so now they don't match up with the location that is reported in the dashboard.
How can I remove the wireless tire guage from one tire and move it to another?
There is a sleeve that I can unscrew but that exposes the stem which does not turn and if you push on it, air comes out of the tire.
Thanks
Dec 27, 2009 at 5:11 AM
BRIAN 1
  • 1,030 POSTS
thats to much work,just relearn the tire positions.Turn ON the ignition, with the engine OFF.
Apply the parking brake.
Cycle the exterior lamp switch from OFF to parking lamps 4 times within 4 seconds. A double horn chirp will sound and the low tire pressure indicator will begin to flash indicating the learn mode has been enabled.
Caution: Over inflating tires may cause personal injury or damage to the tires and wheels. When increasing tire pressure do not exceed the maximum inflation pressure as noted on the tire sidewall. Starting with the left front tire,increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before the 8-10 second pressure increase/decrease time period has been reached, or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached.
After the horn chirp has sounded, proceed as in step 4 for the next 3 sensors in the following order:
• Right front
• Right rear
• Left rear
After the LR sensor has been learned, turn OFF the ignition to exit the learn mode.
After the learn mode has been exited, adjust all tire pressures to the recommended psi.
Dec 27, 2009 at 5:33 AM
CLEME1Q
Thanks, that was much easier!
Dec 28, 2009 at 11:51 AM
