[quote:896dde2088="jganderson"]Electrical problem
2006 Chevy Suburban V8 Two Wheel Drive Automatic 54000 miles
Can someone tell me where to locate the Turn Signal/Flasher Module on my 2006 Suburban?[/quote:896dde2088]
Stop hazard relay, its on the fuse box under the dash.That where mind is it should be square and its black i replace mind and it solved my turn signal and stop hazard problem...hope this help you.
May 11, 2009 at 7:53 AM
