2006 Chevy Suburban Trailer Plug Wiring
82,000 MILES • V8 • 4WD • AUTOMATIC
BLTILGHMAN5
The right brake/turn wire on the trailer plug does not work. It also does not get "hot" when turning the running lights on either. The brake lights on the vehicle work fine. The right turn signal on the vehicle works fine. The running lights on the vehicle work fine. The Dark Green wire leaving the plug appears to run the length of the vehicle with no breaks but I'm not sure where it goes. All fuses appear to be good. What should I check next? There is some type of moduel under the right rear quarter panel but this wire didn't appear to run through that.
Aug 26, 2009 at 3:09 AM
DOCFIXIT
  • 18,828 POSTS
Dk. Green wire runs to I/P fuse box under left side dash check 10 amp fuse RT TRLR ST/TRN
Aug 26, 2009 at 3:30 AM
BLTILGHMAN5
I checked all the fuses under the hood. Is there a fuse box under the dash as well? Thanks.
Aug 26, 2009 at 3:37 AM
BLTILGHMAN5
The vehicles lights work perfectly. Is just the trailer plug thats not getting the power on the right brake/turn light wire.
Aug 26, 2009 at 3:38 AM
DOCFIXIT
  • 18,828 POSTS
Check fuse under left side dash trailer plug wired and fused seperate from vehicle
Aug 26, 2009 at 3:40 AM
BLTILGHMAN5
I will do that. Thank you so much for your help.
Aug 26, 2009 at 3:43 AM
