2005 Chevy Suburban Heater fan will not shut off
70,000 MILES • V8 • 4WD • AUTOMATIC
BENNETT972003
Heater fan will not shut off even when ignition is turned off and key has been removed. chevrolet parts tells me that there is no blower motor relay in this vehicle. Any ideas?
Apr 17, 2010 at 4:12 AM
MERLIN2021
  • 17,250 POSTS
Need to know if it's manual or automatic system?
Apr 17, 2010 at 8:55 AM
BENNETT972003
I would call this an automatic climate control system for the front of the passenger compartment. It has individual thermostat settings for each side and the ac/heater seem to function as needed automatically.
Apr 17, 2010 at 9:01 AM
MERLIN2021
  • 17,250 POSTS
OK that's kinda bad for testing purposes, but I will send you a file by email. This shows test procedure, but without a GM Tech II scan tool, you might not be able to do much with it... You could pay for a scan at a local garage that can read "B" and "U" codes, and then repair it yourself...
Apr 17, 2010 at 9:07 AM
BENNETT972003
Thanks, I do not see the file you referenced. This truck is under a 12/12 warranty for a bit longer. Guess I should take it to the shop.
Apr 17, 2010 at 10:31 AM
MERLIN2021
  • 17,250 POSTS
I emailed it to you, If you didnt get it, I'll resend it, but If you have a warranty, RUN back there and save yourself a boatload of cash!
Apr 17, 2010 at 11:07 AM
BENNETT972003
I will set it up for this week
Apr 17, 2010 at 11:27 AM
MERLIN2021
  • 17,250 POSTS
Very good.
Apr 17, 2010 at 11:35 AM
