2005 Chevy Suburban
DORIDOGG
Computer problem
2005 Chevy Suburban V8 Four Wheel Drive Automatic
All instument gages, fuel, RPM, vol. temp. ect. all go dead and then all light up like a christmas tree and work. A local parts store said that it was due to the trailer ground shorting out. The problem is worse with everything being out for days. On a recent road trip every thing came on after 35-45 min. of driving. Once the Surbaban is turned off everything is dead. Another (friend) mech. says that we need a new cluster. Est. 600$ to 1000$ What is your best suggestion.
Mar 1, 2010 at 10:27 PM
HMAC300
  • 48,601 POSTS
check to see if the plug behnd the cluster is loose and then have the cluster checked for being bad. I think there is a place in fla wher eyou can get those overhauled for about $150. I saw it on truckU tv on the speeed channel i think it was.... they have a web site and it would be on one of the advertisers there....by the way if you bought extended warranty it should be covered.... unless you are out by mileage.
Mar 5, 2010 at 12:32 PM
