2004 Chevy Suburban Temperature Gauge
135,000 MILES • V8 • 4WD • AUTOMATIC
AZ_ADOBE
The temperature guage on our 2004 Suburban occasionally stops working and sometimes shows about 1/2 of what I would expect the temp to be.
At this point Im willing to replace the sending unit since they seem cheap enough. I'd appreciate some directions on where exactly it is located and or another suggestion as to what to look at or replace.
Thanks
Jan 10, 2010 at 1:37 PM
  • 75,988 POSTS
For what liter engine? 5.0. 5.7L ??
Jan 10, 2010 at 8:17 PM
AZ_ADOBE
It is a 4dr 1500 4WD Z71 with a 8 Cyl 5.3L/327 Gas engine.
Jan 11, 2010 at 11:38 AM
  • 75,988 POSTS
Check nearby the thermostat housing or at the housing
Jan 11, 2010 at 11:48 AM
AZ_ADOBE
Can you tell me in relation to the radiator (like top tube coming off the right side of the radiator)? I dont know where the thermostat housing is either.
Jan 11, 2010 at 10:58 PM
  • 75,988 POSTS
You're looking for the Coolant Temperature Sensor is at no. 6 see below
https://images.2carpros.com/forum/automotive_pictures/12900_cts_35.jpg
Jan 12, 2010 at 4:54 AM
AZ_ADOBE
Thanks! I found it. Picture is worth a 1000 words.
I checked the wires and they look ok. I was kind of hoping that I'd see some chewed wiring which would make for an easy fix.
So my next things was to replace sensor. If I unsrew and pull out the sensor will I have coolant pouring out?
Also do you have any other recomendations for things to try?
Jan 12, 2010 at 1:19 PM
