2004 Chevy Suburban Squeaking drive shaft
48,000 MILES • V8 • 2WD • AUTOMATIC
CLEVE
Drive shaft makes a squeaking noise whenever you first push the accelerator. Noise sounds like it is coming from the middle of the shaft. Noise is a chirp, chirp chirp, chirp
Mar 10, 2008 at 11:52 AM
MASTERTECHTIM
  • 4,750 POSTS
you need a new universal joint installed. dont delay too long, it will only get worse. cost is about $100-$175 parts and labor depending where you have it done. hope this helped
Mar 10, 2008 at 12:25 PM
