2004 Chevy Suburban heater blowing cold air
2004 CHEVROLET SUBURBAN
95,000 MILES • V8 • 4WD • AUTOMATIC
DOUGGSF
when the heater is turned on to any setting it will intermittently blow hot and cold air. Watching the temperature gauge it will go from 210 degrees to 240 degrees. when the temp on the gauge is climbing it blows cold air when it falls back the 210 it blows hot air.
thank you
doug norris
Nov 12, 2009 at 8:13 PM
  • CERTIFIED EXPERT
  • 110,176 POSTS
Hi, Doug. This sounds like a typical thermostat problem. Have you made sure the coolant is full? If it is, I would start by replacing the thermostat.
Let me know what you find. Remember, Doug, this could also just be a low coolant problem. (I hope)
Nov 12, 2009 at 8:22 PM
DOUGGSF
Joe thank you will try that!!!!
Nov 12, 2009 at 8:29 PM
