2004 Chevy Suburban dash lights won't shut off when you get
80,000 MILES • V8 • 4WD • AUTOMATIC
AMYMURRAY
We do have the retained accessory power option that they will stay on for 10 minutes after turning the engine off but they usually turn off when you open the door but they will not turn off now and it is draining my battery.
Thanks
Amy Murray
Apr 20, 2009 at 10:42 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
I would first like to apologize for the slow response as we have been busy here at 2CarPros over the last couple weeks.
First ensure that the courtesy/dome lamps operate normally with the switch. If they do not work properly then you will need to test the ground wiring to the liftgate ajar switch. Also ensure that the instrument panel lamp dimmer switch is in the minimum brightness position. Let me know outcome of these inspections..
Thanks for using 2CarPros.com!
Apr 22, 2009 at 5:12 AM
