2003 Chevy Suburban speedomiter
146,000 MILES • V8 • 4WD • AUTOMATIC
JDUB76513
speedomiter does not work, say I am driving 100mph while going 30
Aug 18, 2010 at 6:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
vehicle speed sensor (VSS) on the transmission is probably at fault causing the inaccurate speedometer readings. is the transmission shifiting good? does the odometer seem to be working properly?
Aug 18, 2010 at 11:46 AM
CH3VYCR4ZY
These models had issues with the Instrument Cluster diodes. My 03 had same prob. I replaced the cluster (which is super easy to do) and all gauges returned back to normal. You can go to local parts dealer and you have to fill out a form (to verify mileage) along with your old cluster. Dorman was the parts manufacturer I used, I don't know if there is any others.
Apr 15, 2011 at 3:12 PM
