2003 Chevy Suburban no power right front door
2003 CHEVROLET SUBURBAN
133,000 MILES • V8 • 2WD • AUTOMATIC
MARKCHICAGO5551
I replaced a windor regulator on the front right door. Prior to removing regulator door worked fine and had power after disassembling 1 week later when part arrived battery drained and then no power to that door at all. all other doors work. The switch cluster got water on it while it was in the door but otherwis everything looks normal. checked all fuses and removed circuit breakers for left windows. since the right rear works that doesnt seem to be the issue? is there an inline fuse to that harness?
Jun 6, 2009 at 5:51 AM
SWH213
  • 6 POSTS
the passenger door switch is considered a module - try unplugging the RT Door circuit breaker for 1 minute to reset the module - if that fixes it but it occurs again you will need the module reprogrammed by the dealer. otherwise the water into it ruined it.
Jun 11, 2009 at 9:56 AM
