2003 Chevy Suburban Clicking under the dash upon start up
2003 CHEVROLET SUBURBAN
175,000 MILES • V8 • 2WD • AUTOMATIC
LANETIMD
when I crank the suburban i hear a clicking noise in the dash, the blower is blowing out of the front dash vents after 1 to 2 minutes it stops clicking and starts to blow out of the defrost vents above the dash only! does anyone know what part I need to replace to fix this issue? the rear air works as intended but the front air out of the dash keeps going to the upper defrost mode. I need help trouble shooting this issue, I have five kids that my wife has to transport for various activities and don't have the money to go to a chevy dealer to find out what needs to be done. Please help if you know what I need to buy or do!!
Aug 23, 2010 at 12:05 PM
2CARPRO JACK
  • 11,533 POSTS
Sounds like the mode door actuator is acting up.It is an electric motor that controls which mode (vents) are used.It should be mounted on the HVAC box under the dash, on the drivers side of the box.If you remove the covers and go under the dash when you turn the key on you will be able to feel it clicking, which usually means it is up against its stop or it has stripped internally.Try unplugging it first to be sure the noise goes away
Aug 24, 2010 at 5:11 AM
