2003 Chevy Suburban Blower only works on high.
80,000 MILES • V8 • 2WD • AUTOMATIC
OAKY
The blower for the heat/ ac did only work on level 3 but just recently I have to put it all the way to 5 (the highest) for it to work. It moves a lot of air just like it should on level 5. If I have it on 4 and am driving at a decent speed (40 mph or more) it will blow at a low level. Since I've had the truck it never really moved any air at level 1 but it has now gotten much worse.
Sep 17, 2008 at 6:36 AM
2CARPRO JACK
  • 11,533 POSTS
If the fan is working but not much air is moving,you may have a pluigged cabin filter. Remove the plastic shield under dash passenger side. There is a screw to remove the cover for the cabin filter, pull it out an dsee ifit is full of debris. I have seen them so plugged hardly any air could get through
Sep 17, 2008 at 6:46 AM
