1997 Chevy Suburban Maximum air flow out of the front regis
1997 CHEVROLET SUBURBAN
227,000 MILES • V8 • 2WD • AUTOMATIC
LMATOCHA
While operating the air conditioning at the maximum
blower speed, it appears that the flow out of the upper dash registers isn't sufficient. Although the A/C cools relatively good, including the rear unit, I don't seem to have the volume of air flow out of the registers. What can be the problem?
May 13, 2009 at 12:59 PM
DR LOOT
  • 2,311 POSTS
You either have a vacuum leak, or the flap actuator has a vacuum leak and is not opening the flap or you have a broken clip that is not allowing the flap to open and redistribute the cold air.
May 16, 2009 at 8:58 AM
