2002 Chevy Suburban water leak
JOEANDBOB
Interior problem
2002 Chevy Suburban V8 Four Wheel Drive Automatic
we have a water leak under the drivers seat and it get very damp at times to where it will puddle. Evap. drain is not plugged we have dash out and carpet up and no source really found we came across someone saying that there is a body seem sealant issue a gm service bulletin or something like that. can you help
Oct 22, 2008 at 1:16 PM
DOCFIXIT
  • 18,828 POSTS
The TBS is for rear floor due to a poor seal in fenderwell. I assume when it rains the floor gets wet?It could be door or seal check drain holes in bottom of door. Also colud be comming in seam seal under windage tray ie. in front of windshield.
Oct 23, 2008 at 5:53 AM
