2002 Chevy Suburban Top End Knock
2002 CHEVROLET SUBURBAN
GUSTHEICEMAN
Engine Mechanical problem
2002 Chevy Suburban V8 Four Wheel Drive Automatic 53K miles
I’ve owned a 2002 Suburban LT 5.3L for a year now, its done 53,000 miles. Every morning at start up there’s a top end knock which gradually fades away after about 30 seconds, if I didn’t know better I say it was an empty hydraulic lifter which pumps up. However a pal tells me he heard it’s something to do with piston knock. The question is: Should I be worried and get something done about it?
Best Regards
Gus UK
Nov 25, 2008 at 1:35 AM
  • 31,937 POSTS
Hi there,
Piston knock wont fade after start up, if anything it will get louder, if it is more of a tick, it will be a lifter, if it is a deep knock that fades away, it may be an oil filter that is draining back over night and it is a bit of bearing knock while the oil presser builds up, have a listen and let me know which you feel it is, then i can advise further.
Mark (mhpautos)
Nov 25, 2008 at 2:56 AM
