2002 Chevy Suburban Starter? Battery?
10,000 MILES • V8 • 2WD • AUTOMATIC
RUDYTHREE66
My truck will not start. It just clicks when the key is turned. After 4 days truck started right up several times with no problem. Starter was replaced anyway as it was the original starter. The truck sat for about 5 hours and now it won't start again. The clicking sound is back. What could it be?
Feb 2, 2009 at 6:06 AM
RHALL77
  • 3,361 POSTS
could be a bad battery or a bad battery connection. have the battery load tested and let me know what you find
Feb 2, 2009 at 6:13 AM
  • 75,988 POSTS
Check the crank fuse, park and neutral switch, starter relay and ignition switch
Feb 2, 2009 at 6:19 AM
