2002 Chevy Suburban sounds from drive train when in reverse
98,000 MILES • V8 • 2WD • AUTOMATIC
2002SUBURBANPTC
My suburban suddenly started making a loud sqeaking tyoe sound from the rear area when moving in reverse only with no breaks applied. The sound rate is in line with the speed at which you back up. it gets fater as you move faster. I can not determine if a u-joint would make a sound when turning in one direction versus the other or not. it's a pretty loud sound that almost sound like the sqeak of a large door hinge. Trying to dermine if u-joint, brakes, differential, ????? Just not sure what could make a sound in reverse and not forward. There is no vibration or other symtoms beyond sound
Jan 23, 2010 at 1:55 PM
  • 110,248 POSTS
If it is speed related, it could be a few things. Make sure the differential fluid is full. Next, remove the brake drums and check to make sure there are no broken springs, cables... Finaly, check for excessive play in the u-joints.
Let me know what you find.
Jan 26, 2010 at 2:51 AM
