2002 Chevy Suburban right turn signals not working
ED52ED
Electrical problem
2002 Chevy Suburban
My right turn signals both front and back will not work but the turn indicator on the dash blinks. I have put in tested good bulbs ( both 3157's and the side bulbs) on both front and back at the same time. Still they will not turn on. Swapped the fuse out. No good. Hazard lights works with the exception of the right side.
Hoping it is not wiring harness ( fingers crossed) cause I have no clue on how to test, trace or replace.
Aug 27, 2010 at 12:23 PM
HMAC300
  • 48,601 POSTS
check your grounds on the rear for the tailight and try replacing the turn signal flasher. Not the hazard flasher.
Sep 2, 2010 at 6:37 AM
