2002 Chevy Suburban Power steering assist just stopped.
140,000 MILES • V8 • 4WD • AUTOMATIC
PMGGUY
Last night I made a u-turn with the wheels turned fully to the left with no issues. Upon attempting to turn one mile later I had no power steering at all.
Pump has fluid, belt spins pump fine, no leaks.
No power assist in either turn direction.
I do notice a slight "clunk" in the steering wheel on small bumps, manhole covers, etc..
Jul 31, 2009 at 7:24 AM
PMGGUY
Apparently the shaft going into the pump sheared and thus everything appeared to be working. Upon removing the belt and putting a little pry pressure on the pulley it and the sheared shaft popped right out of the pump. Problem solved!
Aug 1, 2009 at 5:28 AM
