2002 Chevy Suburban Oil psi Question
173,000 MILES • V8 • 2WD • AUTOMATIC
BLPERKS2
I took the vehicle to the dealer today to have it checked and it had no codes and was checked out with no issues. The issue is that the psi gauge reads 40 psi and up depending on rpm. When I shut it off, key still in it settles at around 12 psi pull key out it is 0. Start it up and it goes to 40 again at idle even when warm. Should I be concerned?
Nov 25, 2009 at 12:01 PM
  • 110,248 POSTS
I wouldn't be concerned. The pressure sounds good.
Nov 29, 2009 at 1:32 PM
