2002 Chevy Suburban odometer
2002 CHEVROLET SUBURBAN
125,800 MILES • V8 • 2WD • AUTOMATIC
PULLIN5
i have a 2002 chevy suburban 1500. my question is about the odometer. i have documented numerous occasions where the actual mileage has reset to a previous marker, along with the trip odometer. for example...i drove 15 miles for some errands and returned home, as i got back in the truck later in the day the mileage had reset to 125879 from 125914. the trip odometer no longer read the 15 miles but was at 1.6. no one used the vehicle and i have had suspicion for some time that the odometer was reading improperly but this is the first time i have documented it. everything else, including the speedomemeter, works fine, what could this be?
Oct 23, 2009 at 6:02 PM
MATHIASO
  • 1,209 POSTS
Generally if the speedometer works and the odometer does not , the problem is with the cluster and it is eletrical one.
the instrument cluster must be remove and check resistance at each components
let me know if you have questions
Oct 23, 2009 at 6:32 PM
PULLIN5
just wanted one more thing, would i still need to check the cluster even if the odometer never actually turns off? its always working, never goes blank just resets?
Oct 23, 2009 at 6:44 PM
MATHIASO
  • 1,209 POSTS
Yes there is problem with it, probably a short to ground that why it's allways working when it should be off.
Oct 23, 2009 at 10:30 PM
