2002 Chevy Suburban ginding
101,000 MILES • V8 • 4WD • AUTOMATIC
ATTALOPEZ
iwas changing the front rotors and pads i put the paking brake on and when iwas done with the prject the rear wheel on drivers side now makes noise can you explain why and if there is something wrong with the parking brake system and how to replace them
May 2, 2010 at 3:47 AM
AUTOZONEBRAKESEXPERT
  • 47 POSTS
If your brakes are making grinding sounds when you apply the brakes:
* The most common cause for this condition is when the lining has worn past its service limit and the metal plate is contacting the rotor.
* Some drivers may experience a grinding noise only when the pedal is slightly applied and the vehicle is moving very slow (such as slightly releasing the pedal from a stop position). This operation is normal.
If noise is coming from your brakes, and your brakes squeal when you don’t have your foot on the pedal:
* It is possible the wear indicator is contacting the rotor because the linings are too thin. It could be time to change your brakes.
* Caliper slide pins that are not properly lubricated may bind causing brake drag. Also, corroded brake hardware and/or bracket will cause brake drag as well.
Apr 9, 2011 at 3:44 PM
