2002 Chevy Suburban Front Washer Fluid Pump installation
140,000 MILES • V8 • 2WD • AUTOMATIC
GOLDEN
I have a leaking pump due to battery acid. The pump is located on the washer fluid reservoir. It is a Valeo #22127652. I think I found a replacement pump that works, but without taking the reservoir off, I can't tell how the pump is mounted to the reservoir. The replacement pump appears to somehow stab into the reservoir. Is it screwed in somehow?
Oct 24, 2008 at 12:46 PM
DLOBI
  • 125 POSTS
I believe it is just a tight fit with an o-ring. Pull the old one up and out and push the new one back in place.
Oct 28, 2008 at 4:44 AM
