2002 Chevy Suburban antifreeze coolant leak
150,000 MILES • V8 • 2WD • AUTOMATIC
ERICKA789
I have a coolant leak in the back of the engine I think, but cant trace the extact point of leak. Clue of where the leak is coming from. Was told maybe water-pump is this a hard fix for do it yourself?
Mar 5, 2010 at 11:00 AM
HMAC300
  • 48,601 POSTS
is this a big block? small block? it could be an o-ring at the bak if it's a small block or a freeze plug. Or an inlet gasket. It could also be a h eater hose that is leaking as they goright behind the block. check all of those.
Mar 5, 2010 at 12:08 PM
